[Qgis-developer] Crash when loading layers in memory
A. Golubev golubev at nordcomp.ru
Tue Jan 26 07:39:39 EST 2010
26.01.2010 14:50, Martin Dobias пишет:
> It would be helpful if you provided a backtrace. And what QGIS version
> is that?
> One suggestion: instead of copySymbologySettings() try using something like:
> vl->setRenderer( newlayer->renderer()->clone() )
> IMHO copySymbologySettings() (and hasCompatibleSymbology()) are legacy
> methods and it would be better not to use them as they might be
> removed in future.
> If you're working with QGIS>= 1.4 then layer might use rendererV2()
> and renderer() is NULL. Check isUsingRendererV2() to find out which
> one is valid.
> Martin
Thanks for helping! I`m using QGIS 1.3.0, Qt 4.5.2 on windows XP SP2.
don`t solve the problem, log in attach. I`m trying to run application in
gdb, but it freezes after
Starting program: C:\Qt\qgis-1.3.0_debug/timtut1.exe
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 83: (QgsProviderRegistry) Checking ./plugins for provider plugins
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libcoordinatecaptureplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libcopyrightlabelplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libdelimitedtextplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libdelimitedtextprovider.dll : ... loaded ok (null file filters)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libdiagramoverlay.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libdxf2shpconverterplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libevis.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libgeorefplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libgpsimporterplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libgpxprovider.dll : ... loaded ok (null file filters)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libinterpolationplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libmemoryprovider.dll : ... loaded ok (null file filters)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libnortharrowplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libogrconverterplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 1098: (createFilters) Driver count: 21
fileVectorFilters, unknown driver: REC
fileVectorFilters, unknown driver: Memory
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libogrprovider.dll : ... loaded ok (and with 15 file filters)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/liboracleplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libosmprovider.dll : ... loaded ok (null file filters)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libquickprintplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/librasterterrainplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libscalebarplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libwfsplugin.dll : ..invalid (no type)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libwfsprovider.dll : ... loaded ok (null file filters)
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 215: (QgsProviderRegistry) Checking  ./plugins/libwmsprovider.dll : ... loaded ok (null file filters)
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 190: (loadFromDb) load CRS from C:/Qt/qgis-1.3.0_debug/./resources/srs.db where epsg is 4326
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 1136: (openDb) path= C:/Qt/qgis-1.3.0_debug/./resources/srs.db
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 489: (getRecord) running query: select * from tbl_srs where parameters='+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs'
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 511: (getRecord) trying system srs.db
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 566: (getRecord) retrieved:  select * from tbl_srs where parameters='+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs'
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 369: (createFromProj4) proj4string match search for srsid returned srsid: 3452
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 190: (loadFromDb) load CRS from C:/Qt/qgis-1.3.0_debug/./resources/srs.db where srs_id is 3452
c:/Qt/qgis-1.3.0/src/core/qgscoordinatetransform.cpp: 197: (initialise) Source/Dest CRS equal, shortcircuit is set.
c:/Qt/qgis-1.3.0/src/core/qgsdistancearea.cpp: 155: (setEllipsoid) setEllipsoid: a=
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 489: (getRecord) running query: select * from tbl_srs where parameters='+proj=longlat +ellps=WGS84 +no_defs'
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 566: (getRecord) retrieved:  select * from tbl_srs where parameters='+proj=longlat +ellps=WGS84 +no_defs'
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 369: (createFromProj4) proj4string match search for srsid returned srsid: 3239
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 190: (loadFromDb) load CRS from C:/Qt/qgis-1.3.0_debug/./resources/srs.db where srs_id is 3239
c:/Qt/qgis-1.3.0/src/core/qgscoordinatetransform.cpp: 203: (initialise) Source/Dest CRS UNequal, shortcircuit is NOt set.
c:/Qt/qgis-1.3.0/src/core/qgsscalecalculator.cpp: 44: (setMapUnits) Map units set to 2
c:/Qt/qgis-1.3.0/src/core/qgsscalecalculator.cpp: 129: (calculateGeographicDistance) Distance across map extent (m): 0
c:/Qt/qgis-1.3.0/src/core/qgsscalecalculator.cpp: 80: (calculate) Using conversionFactor of 39.3701
c:/Qt/qgis-1.3.0/src/core/qgsscalecalculator.cpp: 83: (calculate) Can't calculate scale from the input values
+-------------------MapRenderer--------------------------------+
Map units per pixel (x,y) : 0, 0
Pixmap dimensions (x,y) : 1, 1
Extent dimensions (x,y) : 0, 0
0.0000000000000000,0.0000000000000000 : 0.0000000000000000,0.0000000000000000
c:/Qt/qgis-1.3.0/src/core/qgsmaprenderer.cpp: 199: (adjustExtentToSize), Scale (assuming meters as map units) = 1: 0.000000
c:/Qt/qgis-1.3.0/src/gui/qgsmapcanvas.cpp: 1289: (moveCanvasContents) moveCanvasContents: pnt 0,0
c:/Qt/qgis-1.3.0/src/gui/qgsmapcanvasmap.cpp: 129: (copyPixmaps) panning offset:00
c:/Qt/qgis-1.3.0/src/core/qgsscalecalculator.cpp: 44: (setMapUnits) Map units set to 0
Map units per pixel (x,y) : 10253.4, 8435.97
Extent dimensions (x,y) : 10253.4, 8435.97
5655664.6868230002000928,8739052.7335240002721548 : 5665918.1185039998963475,8747488.7024169992655516
c:/Qt/qgis-1.3.0/src/core/qgsmaprenderer.cpp: 199: (adjustExtentToSize), Scale (assuming meters as map units) = 1: 38753127.573699
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 931: (readXML) Reading Spatial Ref Sys from xml ------------------------!
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 190: (loadFromDb) load CRS from C:/Qt/qgis-1.3.0_debug/./resources/srs.db where epsg is 3395
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 739: (setMapUnits) Projection has linear units of Meter
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 942: (readXML) Setting from EPSG id
c:/Qt/qgis-1.3.0/src/core/qgsmaprenderer.cpp: 527: (setDestinationSrs) * Setting destCRS : = +proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs
c:/Qt/qgis-1.3.0/src/core/qgsmaprenderer.cpp: 528: (setDestinationSrs) * DestCRS.srsid() = 1353
c:/Qt/qgis-1.3.0/src/core/qgsmaprenderer.cpp: 531: (setDestinationSrs) Setting DistArea CRS to 1353
c:/Qt/qgis-1.3.0/src/core/qgscoordinatereferencesystem.cpp: 190: (loadFromDb) load CRS from C:/Qt/qgis-1.3.0_debug/./resources/srs.db where srs_id is 1353
c:/Qt/qgis-1.3.0/src/core/qgsmaprenderer.cpp: 694: (updateFullExtent) called.
c:/Qt/qgis-1.3.0/src/core/qgsmaprenderer.cpp: 751: (updateFullExtent) Full extent:
17976931348623157081452742373170435679807056752584499659891747680315726078002
85387605895586327668781715404589535143824642343213268894641827684675467035375169
86049910576551282076245490090389328944075868508455133942304583236903222948165808
559332123348274797826204144723168738177180919299881250404026184124858368.0000000
000000000,1797693134862315708145274237317043567980705675258449965989174768031572
60780028538760589558632766878171540458953514382464234321326889464182768467546703
53751698604991057655128207624549009038932894407586850845513394230458323690322294
8165808559332123348274797826204144723168738177180919299881250404026184124858368.
0000000000000000 : -179769313486231570814527423731704356798070567525844996598917
47680315726078002853876058955863276687817154045895351438246423432132688946418276
84675467035375169860499105765512820762454900903893289440758685084551339423045832
36903222948165808559332123348274797826204144723168738177180919299881250404026184
124858368.0000000000000000,-1797693134862315708145274237317043567980705675258449
96598917476803157260780028538760589558632766878171540458953514382464234321326889
46418276846754670353751698604991057655128207624549009038932894407586850845513394
23045832369032229481658085593321233482747978262041447231687381771809192998812504
04026184124858368.0000000000000000
c:/Qt/qgis-1.3.0/src/core/qgsmaplayer.cpp: 54: (QgsMapLayer) lyrname is ''
c:/Qt/qgis-1.3.0/src/core/qgsmaplayer.cpp: 60: (QgsMapLayer) layerName is ''
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 2102: (readXml) Datasource in QgsVectorLayer::readXml: E:/tmp/qgis_test/Maps/Nueouaea?/Aiiioaoee_WM.shp
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 361: (getProvider) Library name is ./plugins/libogrprovider.dll
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 367: (getProvider) Loaded data provider library
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 368: (getProvider) Attempting to resolve the classFactory function
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 375: (getProvider) Getting pointer to a dataProvider object from the library
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 69: (QgsOgrProvider) Data source uri is E:/tmp/qgis_test/Maps/?????????/?????????_WM.shp
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 118: (QgsOgrProvider) mFilePath: E:/tmp/qgis_test/Maps/?????????/?????????_WM.shp
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 119: (QgsOgrProvider) theLayerIndex:
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 120: (QgsOgrProvider) theLayerName:
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 138: (QgsOgrProvider) Data source is valid
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 139: (QgsOgrProvider) OGR Driver was ESRI Shapefile
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 158: (QgsOgrProvider) Starting get extent
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 165: (QgsOgrProvider) Finished get extent
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 173: (QgsOgrProvider) checking validity
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 175: (QgsOgrProvider) Done checking validity
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 386: (getProvider) Instantiated the data provider plugin
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 387: (getProvider) provider name: ogr
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 2175: (setDataProvider) Instantiated the data provider plugin
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 2189: (setDataProvider) Extent oflayer: 5642872.7286556530743837,8731442.5171194393187761 : 5678057.9833852564916015,8779711.9395732637494802
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field Entity of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field Handle of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field Owner of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field Layer of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field LyrFrzn of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field LyrLock of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field LyrOn of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field LyrVPFrzn of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field LyrHandle of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field Color of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field EntColor of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field LyrColor of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field BlkColor of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field Linetype of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field EntLinetyp of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field LyrLnType of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field BlkLinetyp of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field Elevation of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field Thickness of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field LineWt of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field EntLineWt of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field LyrLineWt of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field BlkLineWt of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field RefName of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field LTScale of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field ExtX of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field ExtY of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field ExtZ of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field DocName of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field DocPath of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field DocType of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field DocVer of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field ScaleX of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field ScaleY of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field ScaleZ of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field Style of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field FontID of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field Text of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field Height of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtAngle of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtWidth of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtOblique of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtGenType of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtJust of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field VertAlign of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtFont of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtBoxHt of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtBoxWd of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtRefWd of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtAttach of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtDir of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field LnSpace of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field SpaceFct of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 241: (setDisplayField) Checking field TxtMemo of 54 total
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 2438: (readSymbology) qgsvectorlayer calling label readXML routine
c:/Qt/qgis-1.3.0/src/core/qgslabel.cpp: 730: (readXML)  called for layer label properties, got node labelattributes
c:/Qt/qgis-1.3.0/src/core/qgsmaplayer.cpp: 100: (setLayerName) new name is '?????????_WM'
c:/Qt/qgis-1.3.0/src/core/qgsmaplayer.cpp: 108: (name) returning name '?????????_WM'
c:/Qt/qgis-1.3.0/src/core/qgsmaplayer.cpp: 54: (QgsMapLayer) lyrname is '?????????_WM'
c:/Qt/qgis-1.3.0/src/core/qgsmaplayer.cpp: 60: (QgsMapLayer) layerName is '?????????_WM'
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 361: (getProvider) Library name is ./plugins/libmemoryprovider.dll
c:/Qt/qgis-1.3.0/src/core/qgsproviderregistry.cpp: 387: (getProvider) provider name: memory
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 2189: (setDataProvider) Extent oflayer: 0.0000000000000000,0.0000000000000000 : 0.0000000000000000,0.0000000000000000
c:/Qt/qgis-1.3.0/src/core/qgsvectorlayer.cpp: 3604: (setCoordinateSystem) -----Computing Coordinate System
c:/Qt/qgis-1.3.0/src/core/qgsmaplayer.cpp: 513: (loadNamedStyle) project fileName: C:/Qt/qgis-1.3.0_debug
c:/Qt/qgis-1.3.0/src/core/qgsmaplayer.cpp: 459: (loadNamedStyleFromDb) Trying to load style for "Point" from "C:/Documents and Settings/golubev/.qgis/qgis.qmldb"
c:/Qt/qgis-1.3.0/src/core/qgsmaplayer.cpp: 459: (loadNamedStyleFromDb) Trying to load style for "Point" from "C:/Qt/qgis-1.3.0_debug/./resources/qgis.qmldb"
c:/Qt/qgis-1.3.0/src/providers/ogr/qgsogrprovider.cpp: 451: (nextFeature) Feature is null
