[Qgis-developer] Crash when loading layers in memory
A. Golubev
golubev at nordcomp.ru
Tue Jan 26 08:37:58 EST 2010
26.01.2010 15:46, Martin Dobias пишет:
> On Tue, Jan 26, 2010 at 1:39 PM, A. Golubev<golubev at nordcomp.ru> wrote:
>> vl->setRenderer( newlayer->renderer()->clone() )
>> don`t solve the problem, log in attach. I`m trying to run application in
>> gdb, but it freezes after
>> Starting program: C:\Qt\qgis-1.3.0_debug/timtut1.exe
> Is the renderer from 'newlayer' valid (i.e. not null, contains
> meaningful values)? And what renderer type is that? Is the renderer in
> 'vl' valid?
> It would be good if you could try it with a newer qgis version and on other OS.
> Martin
Layers and renderers seems to be valid:
newLayer->isValid true type: 0 wkbType: 3
newLayer renderer: "Single Symbol" 0x4646fa8
vl is valid: true type: 0 wkbType: 3
setting renderer
vl renderer: "Single Symbol" 0x643d768
renderer setted
deleting newLayer
newLayer renderer: "Single Symbol" 0x45a0aa0
setting renderer
vl renderer: "Single Symbol" 0x4220120
renderer setted
deleting newLayer
newLayer renderer: "Single Symbol" 0x493cbc0
setting renderer
vl renderer: "Single Symbol" 0x6410758
renderer setted
deleting newLayer
deleting doc
Set the Map Canvas Layer Set
and after that application crashes. Maybe someone could test it?
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100126/4a201c50/sample-0001.zip
