[Qgis-developer] Plugin specific maplayers
Dane Springmeyer
blake at hailmail.net
Tue Jan 26 12:14:30 EST 2010
On Jan 26, 2010, at 8:14 AM, Martin Dobias wrote:
> Dane: you might be also interested in using this new functionality for
> the Quantumnik plugin... From now one can avoid using the
> renderComplete() signal to render map from other sources. Mapnik map
> could be represented as a layer, allowing user to modify it directly
> by showing layer properties or use more such layers at once...
> Regards
> Martin
Martin,
Yes! Great job Mathias. I noticed this and thought the same thing.
Thanks!
Dane
