[Qgis-developer] New watermark plugin using QgsPluginLayer
Mathias Walker mwa at sourcepole.ch
Fri Jan 29 10:49:15 EST 2010
We have added a watermark plugin to the Sourcepole repository, showing the
basic usage of the recently added QgsPluginLayer. With this plugin you can add
a layer showing a semitransparent user-defined image in the lower left corner
of the map.
The tricky bit was calculating the scaling and dimensions of the painter area
in draw(), so the watermark is also rendered correctly in the print composer.
This calculation could eventually be moved to QgsPluginLayer.
There is still the issue of the unscaled rendering in the print composer
preview.
You can find the plugin sources at
http://github.com/pka/qgis-watermark-plugin
Best regards
Mathias Walker
Sourcepole -  Linux & Open Source Solutions
Elestastr. 18   7310 Bad Ragaz  Switzerland
Tel: 081 330 77 11       Fax: 081 330 77 12
mwa at sourcepole.ch  http://www.sourcepole.ch
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100129/3654508d/attachment.bin
