[Qgis-developer] SDA4PP
Giovanni Manghi giovanni.manghi at gmail.com
Fri Jul 2 10:42:26 EDT 2010
On Fri, 2010-07-02 at 05:58 -0700, Mohammed Rashad wrote:
>  How to run SDA4PP. i installed from fetch plugin menu and i got amenu
> on menubar as `SDA4PP`.
> but most options are disabled . will some one post some tutrotal or
> how to on using SDA4PP.
you need to install R and several R packages. If you are on windows you
will need to put the R binary path in the windows enviroment path. In
the plugin menu you can find an item that will help you install the
missing R libraries.
cheers
-- G --
