[Qgis-developer] shapefile clipping behavior in qgis revision
13903
Martin Dobias
wonder.sk at gmail.com
Fri Jul 16 10:36:26 EDT 2010
On Fri, Jul 16, 2010 at 4:06 PM, Jim Hammack <hammack at gotslack.org> wrote:
> Martin,
> No, I have not been able to try it under another OS. I don;t have access
> to anything but Slackware 13.0 and 13.1. I went back to revision 13161,
> which worked under Slackware 13.0, and I have the same clipping problem
> under Slackware 13.1 with this older revision.
> So it must be a difference in underlying libraries, but I haven't tracked
> it down yet. I am using newer versions of the gsl and geos libraries, but
> can't get qgis to build with the older versions that I used under Slackware
> 13.0. There may be other libraries that Slackware has upgraded and I'm
> looking at that now.
I would expect the problem to be caused by GDAL/OGR or GEOS library.
GSL shouldn't be responsible for that as it is used only for
georeferencing.
> Do you know where I can find a list of dependencies so that I can check
> against a known working system?
A list of dependencies is available here:
http://www.qgis.org/wiki/Installation_Guide#General_Build_Notes
Bye
Martin
