[Qgis-developer] Eric4, QScintilla and QGIS
Alex Mandel tech_dev at wildintellect.com
Thu Jul 29 11:54:20 EDT 2010
Try emailing RiverBank Computing and ask if they have a directory of old
releases available.
Thanks,
Alex
FYI, I kinda gave up on ERIC because the autocompletion isn't very good
and mostly use SPE with the Qt tools these days.
On 07/29/2010 06:58 AM, Duarte Carreira wrote:
> Almost!! But doesn't include Qscintilla...
> Duarte
> -----Mensagem original-----
> De: Noli Sicad [mailto:nsicad at gmail.com]
> Enviada: quinta-feira, 29 de Julho de 2010 13:10
> Para: Duarte Carreira
> Cc: G. Allegri; qgis-developer at lists.osgeo.org
> Assunto: Re: [Qgis-developer] Eric4, QScintilla and QGIS
> Try download and installing Orange python 2.5
> It includes all required libraries (Python, PythonWin, NumPy, PyQt,
> PyQwt...), though it will not change any libraries you might already
> have.
> (Also available: Orange for Python 2.5)''
> http://www.ailab.si/orange/nightly_builds.html
> Noli
> On 7/29/10, Duarte Carreira <DCarreira at edia.pt> wrote:
>> Also, I verified the PyQwt installation, and it requires PyQt and Qt. Does
>> not include them... unfortunately.
>> If anyone knows of any other package we could try...
>> Duarte
>> Enviada: quinta-feira, 29 de Julho de 2010 11:32
>> Para: G. Allegri
>> Cc: Duarte Carreira; qgis-developer at lists.osgeo.org
>> You can get PyQt4.4.3 for python2.5 from http://pyqwt.sourceforge.net/
>> PyQwt3D-0.1.6-Python2.5-Qt4.4.1-PyQt4.4.3-NumPy1.2.0.exe
>> Then try to find Qt4.4.3, this might be a better approach.
>> Noli.
>> On 7/29/10, G. Allegri <giohappy at gmail.com> wrote:
>>> +1. I already asked this months ago... It would be very good, also to
>>> have an improved Python Scripting environment in QGis.
>>> giovanni
>>> 2010/7/29 Duarte Carreira <DCarreira at edia.pt>:
>>>> Hi.
>>>> I'm trying to work with Eric4 and QGIS. Eric4 integrates very well with
>>>> PyQT
>>>> but requires QScintilla2 and its python bindings. We can get this by
>>>> installing PyQt [1] or by building QScintilla from scratch [2].
>>>> Problem is, I can't find PyQt binaries anymore at the same version used
>>>> by
>>>> QGIS (QT 4.5.2).
>>>> And no matter how hard I try I always fail to build QScintilla python
>>>> bindings (tried Visual Studio 2008 and mingw32; several versions of
>>>> Qscintilla)... problems arise at the final stage of nmaking the python
>>>> bindings, with several C2440 errors (Conversion loses qualifiers) [3].
>>>> So as a last resort I'm asking the list if anyone can help...
>>>> ...do you have a PyQt distribution that includes QScintilla and is on par
>>>> with
>>>> QGIS? Can you build QScintilla 2.2 or 2.3 using the same QGIS/OSGeo4W
>>>> environment (v2.4 requires sip 4.10 and QGIS is using sip 4.8)?
>>>> The ideal situation would be to include Qscintilla in the  QGIS building
>>>> process... but this may be to much to ask?
>>>> Thanks,
>>>> Duarte
>>>> [1]
>>>> http://www.riverbankcomputing.co.uk/static/Downloads/PyQt4/PyQt-Py2.5-gpl-4.7.4-1.exe
>>>> [2]
>>>> http://www.riverbankcomputing.co.uk/static/Docs/QScintilla2/index.html
>>>> [3] error C2440: 'initializing' : cannot convert f rom 'const char *' to
>>>> 'char *'
