[Qgis-developer] Qt development on Gnome
Ivan Mincik ivan.mincik at gista.sk
Fri Jun 4 03:28:15 EDT 2010
On Thursday 03 June 2010, you wrote:
> Hi Ivan,
> generally the differences come more from the theme used than the
> dekstop manager,
> clearlooks or elementary are really goods themes fitting perfectly
> with Qt based apps (and I really appreciate opening files with the
> gnome file selector into QGIS). After that, you can use QtDesigner
> under Gnome without problems
Thanks, You are perfectly right. Using Clearlooks theme makes very good Gnome integration and widgets looks placed
correctly.
Thanks a lot.
Ivan Mincik
