[Qgis-developer] GdalTools in trunk
Giuseppe Sucameli
brush.tyler at gmail.com
Fri Jun 4 07:20:57 EDT 2010
Fixed from r13643.
Now every strings after the version are ignored.
Cheers.
On Fri, Jun 4, 2010 at 12:21 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> I guess having 'dev' in the release name is causing issues.... (see below).
> Regards
> Tim
> Couldn't load plugin GdalTools due an error when calling its initGui()
> method
> Traceback (most recent call last):
> File "/home/timlinux/apps/share/qgis/python/qgis/utils.py", line
> 159, in startPlugin
> plugins[packageName].initGui()
> File
> "/home/timlinux/apps/share/qgis/python/plugins/GdalTools/GdalTools.py",
> line 86, in initGui
> self.GdalVersion = Utils.Version( Utils.GdalConfig.version() )
> File
> "/home/timlinux/apps/share/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py",
> line 347, in version
> return Version(gdal.VersionInfo("RELEASE_NAME"))
> File
> line 613, in __init__
> self.vers = self.string2vers(ver)
> File
> line 623, in string2vers
> vers[1] = int(nums[1])
> ValueError: invalid literal for int() with base 10: '8dev'
> Python version:
> 2.6.5 (r265:79063, Apr 16 2010, 14:15:55)
> [GCC 4.4.3]
> QGIS version:
> 1.5.0-Trunk Trunk, 13642
> Python path: ['/home/timlinux/apps/share/qgis/python',
> '/home/timlinux/.qgis/python', '/home/timlinux/.qgis/python/plugins',
> '/home/timlinux/apps/share/qgis/python/plugins',
> '/usr/local/lib/python2.6/dist-packages/django_tinymce-1.5-py2.6.egg',
> '/usr/local/lib/python2.6/dist-packages/gearman-1.5.0-py2.6.egg',
> '/usr/local/lib/python2.6/dist-packages/django_simple_captcha-0.1.7-py2.6.egg',
> '/usr/local/lib/python2.6/dist-packages/django_extensions-0.5-py2.6.egg',
> '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
> '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
> '/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages/PIL',
> '/usr/lib/python2.6/dist-packages/gst-0.10',
> '/usr/lib/pymodules/python2.6',
> '/usr/lib/python2.6/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.6/gtk-2.0',
> '/usr/local/lib/python2.6/dist-packages',
> u'/home/timlinux/.qgis//python/plugins',
> '/home/timlinux/apps/share/qgis/python/plugins/fTools/tools',
> '/home/timlinux/apps/share/qgis/python/plugins/GdalTools/tools',
> '/home/timlinux/apps/share/qgis/python/plugins/GdalTools', '.']
> On Fri, Jun 4, 2010 at 4:33 AM, Giuseppe Sucameli <brush.tyler at gmail.com>
> wrote:
> > Hi guys,
> > now GdalTools plugin v.1.2.0 is in trunk.
> > So, if you have to open a ticket you must use the qgis trac.
> > For the translators: remember that you must update the translations
> > on the qgis repository and not in the Faunalia one.
> > Cheers.
> > Giuseppe Sucameli
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100604/8d0be04c/attachment.html
