[Qgis-developer] OpenLayers plugin
Borys Jurgiel borysiasty at aster.pl
Tue Jun 8 09:49:53 EDT 2010
Dnia wtorek, 8 czerwca 2010 o 14:00:45 motta.luiz at gmail.com napisał(a):
> Borys,
> Mybe helpfull
> I make some changes in Plugin, see:
> http://github.com/pka/qgis-openlayers-plugin/tree/master/openlayers/
Wow! The new version works perfectly! :-) Great job!
The problem was because that "upgrade" pushed me back to 0.25. Note that
version 0.25 is higher than 0.4 for the installer, because each section is
considered as an integer.
You can find it controversial, but it's better then considering version
numbers as fractions. In such case, there were problems between versions 0.9
and 0.10, or three-sectional versions as 0.9.1.
So instead 0.25 that version just should be named 0.2.5
Regards,
B.
