[Qgis-developer] Re: GdalTools versions
Giuseppe Sucameli
brush.tyler at gmail.com
Tue Jun 8 11:25:05 EDT 2010
Hi Martin,
now the modules import is done by the following lines:
*from tools import GdalTools_utils as Utils
from tools import ( doBuildVRT, doContour, doRasterize, doPolygonize,
doMerge, doSieve, doProximity, doNearBlack )
from tools import ( doWarp, doGrid, doTranslate, doClipper, doInfo,
doProjection, doOverview, doRgbPct, doPctRgb )
from tools import ( doSettings, doAbout )*
and GdalTools works fine until I reload it.
In fact, If I reload it I get this error:
File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 150, in
startPlugin
plugins[packageName] = package.classFactory(iface)
File "/usr/local/share/qgis/python/plugins/GdalTools/__init__.py", line
30, in classFactory
from GdalTools import GdalTools
File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 291, in
_import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/usr/local/share/qgis/python/plugins/GdalTools/GdalTools.py", line
42, in
raise ImportError( error_str )
ImportError: cannot import name doBuildVRT
I tried to change all the import lines, using i.e.
*import tools.doBuildVRT as doBuildVRT
but nothing.
How can I resolve it? I guess this error it's not related with GdalTools...
Cheers.
On Tue, Jun 8, 2010 at 1:26 PM, Borys Jurgiel <borysiasty at aster.pl> wrote:
> Dnia wtorek, 8 czerwca 2010 o 13:07:53 Giuseppe Sucameli napisał(a):
> > Hi Borys,
> > On Mon, Jun 7, 2010 at 10:39 PM, Borys Jurgiel <borysiasty at aster.pl>
> wrote:
> > > if QGis.QGIS_VERSION[2] < 5:
> > > [set paths and install the local translator]
> > I'm not sure the code above works always.
> > When the QGis'll become 2.0 that condition still works? AFAIK it won't.
> > Regards.
> Right, it seems the API changes won't be so huge to block all the 1.x
> plugins
> by default, so they can be prepared for 2.0. So you can use:
> Gis.QGIS_VERSION[0:3] < '1.5'
> (sorry for previous mistake, it returns a string, not an int)
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100608/88e3b4de/attachment-0001.html
