[Qgis-developer] R: QGIS-trac Digest, Vol 50, Issue 62
Massimo Di Stefano
massimodisasha at yahoo.it
Mon Jun 14 07:11:27 EDT 2010
Have you a fix for it,
or can you point us to the needed changes (which file/line) or suggestion to debug it ?
SDA4PP plug-in is affected by the same problem.
Thanks.
Changed 56 seconds ago by lutra status changed from new to closedresolution set to invalidit is also a 3rd party plugin so in any case the problems need to be reported in the qgis-dev mailing list.
Message: 9
Date: Sat, 12 Jun 2010 14:42:30 -0000
Subject: [QGIS-trac] Re: [Quantum GIS] #2803: manageR don't works on
OSX
Cc: qgis-trac at lists.osgeo.org
Message-ID: <044.bc3c12e95a905a51c04409d2a5dc7e49 at qgis.org>
Content-Type: text/plain; charset="utf-8"
#2803: manageR don't works on OSX
Reporter: epifanio | Owner: borysiasty
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.5.0
Component: Python plugins and bindings | Version: HEAD
Keywords: R , rpy2, manageR | Platform_version: osx
Platform: OS X | Must_fix: No
Status_info: 0 |
Comment(by pcav):
It should be the usual problem with paths.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2803#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS,
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100614/9f23642a/attachment.html
