[Qgis-developer] How to turn GRASS commands from tabs to a script? (where is toolbox metadata located?)
Stefan Kiefer st_kiefer at web.de
Sat Mar 13 08:36:21 EST 2010
What about using grass directly? IF you work with unix like OS you
simply can write a script for automatisation (i.e. with perl, python or
shell-script). I think there is no need for bothering qgis for your
special needs. I belive under Windows is the same because there you also
should have installed Cygwin when Grass is installed.
cheers
Stefan
Am Freitag, den 12.03.2010, 16:34 +0100 schrieb Stefan Keller:
> Dear all
> I'm analyzing some data with grass within qgis. Now there's the grass
> plugin and it's toolbox. This opens nicely a new tab when issueing a
> new grass command, like r.in.ascii, then r.reclass, etc. There's also
> a "Browser" which displays every command as comment (e.g. aspect map
> elev = dhm at mymap zfactor = 1.00 min_slp_allowed = 0.000000").
> Now I want to automate this series of commands using a script (or a
> batch command)!
> How do I do that easiest?
> My approach would be to fetch the comment data from the GRASS plugin
> toolbox browser - but I can't find the location where this metadata is
> stored?
> -S.
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100313/107c98be/attachment.html
