[Qgis-developer] How to turn GRASS commands from tabs to a script?
(where is toolbox metadata located?)
Micha Silver
micha at arava.co.il
Sun Mar 14 12:59:39 EDT 2010
Stefan Keller wrote:
> Many thanks to Micha and Stefan!
> I'm a GRASS and QGIS noob using GRASS shell (text interface) was what
> I thought of initially.
> @Micha Silver: I hope that's what you mean by [GRASS commands in the
> Toolbox "shell"]?
> I'm looking for a generic solution which works the same on Unix and
> Windows. (Btw. Cygwin is no option for productive use and delivery -
> serious cross-platform project must offer standalone executables).
> Still, I am little bit unsettled since I thought it would be easier to
> automate a tool like GRASS which is text command based...
> See below my solution so far. It's not yet really working because it
> seems that only r.in.* commands put itself into the comments section
> beginning with line 9 (in hist subdirectory of a GRASS mapset).
I think the file you want to be looking at is
$GISDBASE/$LOCATION_NAME/$MAPSET/.bash_history
> Any GRASS wizards around?
> -S.
> --- FILE: gen-grass-shell-script.py ---
> # gen-grass-shell-script.py
> # Generates a GRASS shell script from GRASS raster layer descriptions
> (to be run from GRASS shell)
> # Created 2010 by SFK, www.gis.hsr.ch. LGPL.
> # USAGE:
> # 1. from OS shell: > python gen-grass-shell-script.py > gen-mylayers.sh
> # 2. edit gen-mylayers.sh if needed
> # 3. start GRASS shell (text interface): sh gen-mylayers.sh
> # TODO: extract commands like aspect from line 8 or so.
> # TODO: Cleanup code.
> import glob
> from datetime import date
> import os
> # *** edit these constants first **
> GISDBASE = d:/gis/labs/raster_lab/grassdata/'
> LOCATION = 'gaemse'
> MAPSET = 'gaemse'
> # *** end of user edit block **
> print "#!/bin/sh"
> print "# Script generated on " + date.today().strftime("%d %b %Y")
> print "# Location: " + LOCATION + ", Map: " + MAPSET
> print
> for filepath in glob.glob(GISDBASE + LOCATION + '/' + MAPSET + '/hist/*'):
> f = open(filepath)
> i = 0;
> cmd = "";
> for line in f:
> i = i + 1
> line = line.rstrip('\n')
> if (i == 8):
> generatedby = line
> if (i >= 9):
> if (line == ""):
> continue
> if (line[-1] == "\\"):
> cmd = cmd + line[:-1]
> else:
> cmd = cmd + line + " "
> if (i >= 8):
> print "# Layer " + os.path.basename(filepath)
> print "# " + generatedby
> print cmd
> print
> # Example output:
> # > python gen-grass-shell-script.py > gen-mylayers.sh
> # #!/bin/sh
> # # Script generated on 14 Mar 2010
> # # Location: gaemse, Map: gaemse
> # # Layer as85
> # # generated by r.in.gdal
> # r.in.gdal -o input="d:/gis/labs/raster_lab/datasource/as85.txt" output="as85"
> # # Layer aspect
> # # generated by r.slope.aspect
> # aspect map elev = my_dhm at user1 zfactor = 1.00 min_slp_allowed = 0.000000
> 2010/3/13 Stefan Kiefer <st_kiefer at web.de>:
>> What about using grass directly? IF you work with unix like OS you simply
>> can write a script for automatisation (i.e. with perl, python or
>> shell-script). I think there is no need for bothering qgis for your special
>> needs. I belive under Windows is the same because there you also should have
>> installed Cygwin when Grass is installed.
>> cheers
>> Stefan
>> Am Freitag, den 12.03.2010, 16:34 +0100 schrieb Stefan Keller:
>> Dear all
>> I'm analyzing some data with grass within qgis. Now there's the grass
>> plugin and it's toolbox. This opens nicely a new tab when issueing a
>> new grass command, like r.in.ascii, then r.reclass, etc. There's also
>> a "Browser" which displays every command as comment (e.g. aspect map
>> elev = dhm at mymap
>> zfactor = 1.00 min_slp_allowed = 0.000000").
>> Now I want to automate this series of commands using a script (or a
>> batch command)!
>> How do I do that easiest?
>> My approach would be to fetch the comment data from the GRASS plugin
>> toolbox browser - but I can't find the location where this metadata is
>> stored?
>> -S.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
