[Qgis-developer] espg element removed from qgs project file?
Richard Duivenvoorde
rdmailings at duif.net
Wed Mar 24 11:35:52 EDT 2010
Hi Devs,
trying to update the mapserver-export part of the documentation with a
fresh build from qgis-trunk I catched an error for the plugin ...
It have an error in the WEB part of the mapserver because in the 'old'
version of qgs project files there was always an element 'epsg' which
held the epsg-number for current project.
It is used to write following line in the WEB part:
'ows_srs' 'EPSG:28992'
Questions:
- is the removeal of the epsg-element deliberate?
- if so, should I use authid-element-value then to get the right value
for ows_srs, and will this always be an EPSG:xxxxx value?
I will fix this in the mapserver asap, because at this moment the plugin
is plain broken :-(
Regards,
ps old and new <destinationsrs>-part of qgs files:
NEW:
<destinationsrs>
<spatialrefsys>
<proj4>+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+k=0.9999079 +x_0=155000 +y_0=463000 +ellps>
<srsid>2517</srsid>
<srid>28992</srid>
<epsg>28992</epsg>
<description>Amersfoort / RD New</description>
<projectionacronym>sterea</projectionacronym>
<ellipsoidacronym>bessel</ellipsoidacronym>
<geographicflag>false</geographicflag>
</spatialrefsys>
</destinationsrs>
OLD:
<destinationsrs>
<spatialrefsys>
+k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +units=m>
<srsid>2517</srsid>
<srid>28992</srid>
<authid>EPSG:28992</authid>
</spatialrefsys>
</destinationsrs>
