[Qgis-developer] Compiling Error
Jürgen E. Fischer jef at norbit.de
Fri Mar 26 08:24:33 EDT 2010
Hi Horst,
On Fri, 26. Mar 2010 at 11:17:06 +0100, Düster Horst wrote:
>    I just tried to compile r13163 but unfortunately I get the following error
>    message when I run make install
>    CMake Error at src/plugins/grass/modules-common/cmake_install.cmake:36
>    (FILE):
>    file INSTALL cannot find file
>    "/usr/local/src/sogis/qgis_src/trunk/src/plugins/grass/modules-common/r.circle.png"
>    to install.
The file was renamed.  Do a clean build or touch CMakeLists.txt to force a
cmake run.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
