[Qgis-developer] annotation tools
Marco Hugentobler marco at hugis.net
Mon Mar 29 04:15:14 EDT 2010
Hi John
What do you mean with 'any font changes are not sticking on OS X' ? Is it that
you select a font and it does not appear in the item?
Is there a place in QGIS where the native Mac font dialog already appears?
Because I'm not sure from the docs if QFontDialog::getFont really uses the
native dialog.
> I noticed if
>  an annotation is selected in the canvas, the resize widgets are printed
>  from the composer
Right, this if fixed now.
> Also, font sizes are incorrect when exporting to svg on
>  my system. PDF export looked good.
Hm, true. And it also happens in the form widgets. This is difficult, I remember
that I used pixel sized fonts in the mapcomposer to avoid this problem with
the labels. But with the form items, it is not possible because the Qt widget
handles the font scaling.
Regards,
Marco
Am Freitag, 26. März 2010 18.57:29 schrieb John C. Tull:
> Hi Marco,
> This is looking like a nice start. I would like to see the font settings
>  changed to a standard font dialog, preferably allowing the native mac
>  dialog on OS X systems using Qt-cocoa. Currently, any font changes are not
>  sticking on OS X.
> The annotations worked on both the map and composer canvasses. I noticed if
>  from the composer. Also, font sizes are incorrect when exporting to svg on
> Cheers,
> John
> On Mar 26, 2010, at 2:39 AM, Marco Hugentobler wrote:
> > Hi John
> > Thanks for testing. You are right, the deleteAnnotation has been left in
> > the header, but not in the cpp.
> > The updated source package is on:
> > www.hugis.net/100326_annotation_tools.tgz
> > Regards,
> > Marco
> > Am Freitag, 26. März 2010 03.05:42 schrieb John C. Tull:
> >> Hi Marco,
> >> I was unable to get the plugin to compile:
> >> [ 82%] Building CXX object
> >> src/plugins/annotation_tools/CMakeFiles/annotationplugin.dir/qrc_annotat
> >>io n_tools.cxx.o Linking CXX shared module libannotationplugin.so
> >> Undefined symbols:
> >>  "QgsAnnotationPlugin::deleteAnnotation()", referenced from:
> >>      QgsAnnotationPlugin::qt_metacall(QMetaObject::Call, int, void**)in
> >> moc_qgsannotationplugin.cxx.o ld: symbol(s) not found
> >> collect2: ld returned 1 exit status
> >> make[2]: *** [src/plugins/annotation_tools/libannotationplugin.so] Error
> >> 1 make[1]: ***
> >> [src/plugins/annotation_tools/CMakeFiles/annotationplugin.dir/all] Error
> >> 2 make: *** [all] Error 2
> >> Regards,
> >> John
> >> On Mar 25, 2010, at 3:55 AM, Marco Hugentobler wrote:
> >>> Hi devs
> >>> I'd like to publish the first version of the annotation tools (that
> >>> were also presented at the hackfest in Pisa) for testing:
> >>> www.hugis.net/100324_annotation_tools.tgz
> >>> Just copy it to you src/plugins/ directory and unpack. Then, insert
> >>> 'annotation_tools' as new subdirectory into src/plugins/CMakeLists.txt.
> >>> To make the items also appear in the print composer, you need to enable
> >>> the lines 273 and 314 in src/core/qgscomposermap.cpp
> >>> The plugin provides the functionality to place balloons for textboxes
> >>> and designer forms on the map, providing various possibilities for
> >>> symbolisations.
> >>> At the moment, it is a plugin, but I'd like to bring the annotation
> >>> classes into the gui library. What do you think?
> >>> Regards,
> >>> Marco
Dr. Marco Hugentobler
HUGIS GmbH
Webereistrasse 66
CH-8134 Adliswil
marco at hugis.net
http://homepage.hispeed.ch/hugis
Technical Advisor QGIS Project Steering Committee
