[Qgis-developer] mapserver plugin,
qgs project xml and label-elements
Richard Duivenvoorde
rdmailings at duif.net
Mon Mar 29 15:58:15 EDT 2010
Thanks Martin,for your insights.
I will use the solution you provide.
Regards,
Richard
Martin Dobias wrote:
> On Mon, Mar 29, 2010 at 10:28 AM, Richard Duivenvoorde <richard at duif.net> wrote:
>> Hi Martin,
>> my 'problem' with using the context of the tag is that the minidom retrieves
>> ALL child label-elements from the maplayer element, and I do not know an
>> easy name to distinguish the right 'label' from all the labels I retrieve
>> from the maplayer element...
>> -maplayer
>> \-LABEL // 1 or 0 == haslabel
>> \-uniquevalue
>> \-symbol
>> \-LABEL // txt == legendlabel
>> \labelattributes
>> \-LABEL fieldname=X text=Y // actual labels
> Right, so you can take all returned <label> elements and check what is
> their parent (using parentNode attribute) to determine their context.
>> Your argument about 'incompatibility for the projectfiles'. Is that valid?
>> We do not guarantee backwards compatibility do we? And it makes the project
>> file more understandable and easier to use for plugin builders.
> Well, I wasn't really clear. We try not to modify project file format
> among releases of QGIS. Ideally, project created in 1.0 should work
> perfectly in 1.4 and vice versa. But this is not always possible: so
> if we do any changes to project file format, we aim to keep
> compatibility with projects from older releases. There is a small
> framework for transformation of older project files to newer project
> files (see QgsProjectFileTransform). If there are any
> incompatibilities, the older project file is first transformed
> on-the-fly to work with current version and then loaded (as if it was
> a project file from current version). So, when a change in project
> file format is introduced in qgis 1.7, then qgis 1.3 probably will
> have some problems reading it. Therefore we try to avoid such changes
> if they're not necessary.
> I hope other devs have the same opinion, if not, please tell me :-)
> If we changed the names of <label> element tags for 1.5, the new
> projects will get incorrect labeling settings in older versions of
> QGIS. That's why I think it's better to keep things as they.
>> The plugin is fortunatly a 'standard qgis plugin', so is always delivered as
>> is with a current version. And will work with that version of the project
>> file format :-)
> If you parse the xml code manually, you may need to take care of the
> differences too (or tell the user he needs to save the project in the
> qgis version the plugin expects). That's another win of using
> QgsProject class: it will handle the differences automatically and you
> don't have to bother with it.
> Cheers
> Martin
> Qgis-developer mailing list
