[Qgis-developer] same old bugs in the print composer
John C. Tull john.tull at wildnevada.org
Mon May 3 22:09:53 EDT 2010
Hi Maciej,
Your screen image was either stripped or not attached.
I, also, had reported something similar recently:
http://trac.osgeo.org/qgis/ticket/2598
Cheers,
John
On May 3, 2010, at 2:06 PM, Maciej Sieczka wrote:
> Hi,
> I have set-up a composition as on the screendump attached, taken in the QGIS print composer window. However, any output type (pdf, png, svg) doesn't look the same as the view in the composer - pdf and png have fill patterns and point symbol scales different in the compsers legend, in the compsers map view and in the the map view of the main QGIS window. Svg output is mainly missing the legend and arrow.
> These all look similar to old bugs that have been present in the print composer for years. Are these going to be fixed someday, or are they bugs in QT, elsewhere, and cannot be fixed?
> Best,
> Maciek
> Maciej Sieczka
> http://www.sieczka.org
> Qgis-developer mailing list
