[Qgis-developer] Re: PostGIS Query Editor plugin - proposal to
	remove Qt.WindowCloseButtonHint
    Ivan Mincik
    ivan.mincik at gmail.com
    Sun May  9 10:25:48 EDT 2010
Horst Düster wrote:
> Am 09.05.2010 12:26, schrieb Ivan Mincik:
>>> This is my newest version with the decision depending of the Qt
>>> Version.
>>> Please remove all flags which will not work with prior Qt 4.5 versions
>>> and send it back to me.
>> Ok, this is my correction.
>> I suggest "if qVersion()>= '4.5':" because there is a problem also
>> with 4.4, not with 4.3.
>> Whole file is attached. Thanks a lot.
>> Ivan
> Thank you for your collaboration. I just upgraded the pyqgis.org
> repository. Please try it and let me know if it works.
> Horst
Yes, it is working now. Thanks.
