[Qgis-developer] qWebView in a plugin - the windows closes immediately
Martin Dobias wonder.sk at gmail.com
Tue May 11 11:01:52 EDT 2010
On Tue, May 11, 2010 at 4:34 PM, baobazz <baobazz at hotmail.fr> wrote:
> I've got problems with the web windows: it automatically closes..
>  def run(self):
>        #code to get the layer_id
>    view=QWebView()
>    url="http://info_layer.php?layer="+layer_id
>    view.load(QUrl(url))
>    view.show()
The problem is that the "view" object is valid only within the context
of run() method - it gets destroyed automatically when the method is
finished. You can set the "view" object to be an attribute of the
class, i.e. self.view = QWebView(). This will destroy the view when
the plugin instance is deleted. Other possibility is to set parent of
the QWebView instance - the ownership will be transferred to the
parent and it will be deleted when the parent is deleted - see QObject
reference.
Martin
