[Qgis-developer] HTML imagemap not working?
Ivan Mincik ivan.mincik at gmail.com
Sun May 16 03:40:41 EDT 2010
> attached you find a newer version (0.4.4) of the html image plugin.
> can you please have a look, and see if this is better now?
> if ok, I will sent it to the plugin repository.
> The problem was the way I handled the combination of layers without
> projection information, and qgis projects using 'on the fly projection' was.
> The tests I did using Ivan's data:
> - fresh (wgs84) project without otf (on the fly projection) and add
> shapefile (at loading give it custom crs)
> - same (wgs84) project but now enable on the fly projection (map will
> slightly change)
> - fresh custom crs project, add the (custom crs) shape without otf
Hi, it is working now with all kind events. Thanks.
Ivan
