[Qgis-developer] problems with SDA4PP plugin
Giovanni Manghi
giovanni.manghi at gmail.com
Mon May 17 05:59:04 EDT 2010
Hi Paolo,
On Sat, 2010-05-15 at 05:25 +0200, Paolo Cavallini wrote:
> Hi all.
> I'm having trouble with the SDA4PP plugin. Upon installation, it requires
> several additonal packages and crashes [0].
> I install the needed packages, but it fails to load rJava, and it gets
> deactivated [1].
> I think the dependency on rJava is very heavy, and should be avoided if at
> all possible.
under ubuntu linux I'm not getting your problems/crashes after having
installed the necessary R packages. Did you get the errors/crashes using
a particular tool?
Under windows it seems that for now the plugin works only the standalone
version of qgis.
Cheers
-- Giovanni --
