[Qgis-developer] problems with SDA4PP plugin
Carson Farmer
carson.farmer at gmail.com
Mon May 17 07:59:43 EDT 2010
Should still work, rpy2 is how the plugin interacts with R, and as
long as rpy2 is installed via osgeo4w it should work. It's possible
that you'll have to add the path to you R installation to your path
environment variable, but this should be the same if you've installed
rpy2 for use with the standalone qgis as well.
Carson
On Mon, May 17, 2010 at 12:51 PM, Giovanni Manghi
<giovanni.manghi at gmail.com> wrote:
> On Mon, 2010-05-17 at 12:44 +0100, Carson Farmer wrote:
>> > Under windows it seems that for now the plugin works only the standalone
>> > version of qgis.
>> Plugins that use the rpy2/rpy python library (of which I believe
>> SDA4PP is one) should still work under the osgeo4w version of qgis as
>> long as you've installed rpy2/rpy using the osgeo4w installer.
> Hi,
> I was speaking about R dependencies, not pyhton.
> Cheers
> -- Giovanni --
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation
National University of Ireland, Maynooth,
http://www.carsonfarmer.com/
