[Qgis-developer] Re: Couldn't load PyQGIS after Upgrade to Ubuntu 10.04 LTS
Volkan Kepoglu vkepoglu at gmail.com
Fri May 21 02:05:01 EDT 2010
after (auto)update for all qgis libs in the synaptic manager, the error is
solved.
sorry for false reporting.
On Wed, May 19, 2010 at 11:13 PM, Volkan Kepoglu <vkepoglu at gmail.com> wrote:
> The error is:
> Couldn't load PyQGIS.
> Python support will be disabled.
> Traceback (most recent call last):
>   File "", line 1, in
> RuntimeError: the sip module implements API v7.0 to v7.1 but the qgis.core
> module requires API v6.0
> Python version:
> 2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
> [GCC 4.4.3]
> Python path:
> ['/usr/share/qgis/python', '/home/volkan/.qgis//python',
> '/home/volkan/.qgis//python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
> '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
> '/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages/Numeric',
> '/usr/lib/python2.6/dist-packages/PIL',
> '/usr/lib/python2.6/dist-packages/gst-0.10', '/usr/lib/pymodules/python2.6',
> '/usr/lib/python2.6/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.6/gtk-2.0',
> '/usr/local/lib/python2.6/dist-packages']
> Volkan.
Regards,
Volkan Osman Kepoglu
PhD Candidate
GGIT Department in METU,
http:/ggit.metu.edu.tr
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100521/03e7e555/attachment.html
