[Qgis-developer] Re: How to use QPixmap argument in saveAsImage()
mreyes
reyesmarcelo at gmail.com
Wed May 26 11:20:14 EDT 2010
Hi pfth,
did you find a solution to this problem?
I'm trying to print a map using the code Martin provided you but I get the
exact same problem. The application crashes a few seconds after the ong is
created. The crash is caused by the same line of code.
Marcelo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-use-QPixmap-argument-in-saveAsImage-tp4457393p5104128.html
Sent from the qgis-developer mailing list archive at Nabble.com.
