[Qgis-developer] SD4PP
Paolo Cavallini
cavallini at faunalia.it
Thu May 27 03:53:26 EDT 2010
Hi all.
Testing SD4PP, got a number of errors, eg:
Errore durante l'esecuzione di codice Python:
File "/home/paolo/.qgis/python/plugins/SDA4PP/kriging.py", line 551, in
runApply
check = self.btnVar_changed(funName="runApply")
File "/home/paolo/.qgis/python/plugins/SDA4PP/kriging.py", line 347, in
btnVar_changed
error = krigingRpart.doSpatialAnalysis(self.R, index= self.index)
File "/home/paolo/.qgis/python/plugins/SDA4PP/krigingRpart.py", line 27, in
doSpatialAnalysis
s = r("point_df = as.data.frame(v_spdf)")
File "/usr/lib/python2.6/dist-packages/rpy2/robjects/__init__.py", line
257, in __call__
res = self.eval(p)
File "/usr/lib/python2.6/dist-packages/rpy2/robjects/functions.py", line
83, in __call__
return super(SignatureTranslatedFunction, self).__call__(*args, **kwargs)
35, in __call__
res = super(Function, self).__call__(*new_args, **new_kwargs)
RRuntimeError: Error in as.data.frame(v_spdf) : object 'v_spdf' not found
Versione Python:
2.6.5 (r265:79063, Mar 18 2010, 23:59:47)
[GCC 4.4.3]
runApply
btnVar_changed
doSpatialAnalysis
257, in __call__
res = self.eval(p)
83, in __call__
35, in __call__
Versione Python:
[GCC 4.4.3]
Versione di QGIS:
1.5.0-Trunk Trunk, 13572M
File "/home/paolo/.qgis/python/plugins/SDA4PP/kriging.py", line 126, in
runClose
sda4ppRoptions.closeRplot(self.R)
File "/home/paolo/.qgis/python/plugins/SDA4PP/sda4ppRoptions.py", line 135,
in closeRplot
for i in range(int(str(n[0]))):
TypeError: 'RObject' object does not support indexing
http://faunalia.it/pc
