[Qgis-developer] Compile error on debian testing
Carlos Dávila
cdavilam at orangecorreo.es
Fri May 28 13:12:15 EDT 2010
I get the following error compiling trunk. All my gt packeges are up to
date (4.6.2-4). Should I use "unstable" packages (4.6.2-5) or is there
any other solution?
[ 0%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprenderer.cxx.o
/home/carlos/Paquetes/qgis/trunk/build/src/core/moc_qgsmaprenderer.cxx:14:2:
error: #error "This file was generated using the moc from 4.5.3. It"
/home/carlos/Paquetes/qgis/trunk/build/src/core/moc_qgsmaprenderer.cxx:15:2:
error: #error "cannot be used with the include files from this version
of Qt."
/home/carlos/Paquetes/qgis/trunk/build/src/core/moc_qgsmaprenderer.cxx:16:2:
error: #error "(The moc has changed too much.)"
make[2]: ***
[src/core/CMakeFiles/qgis_core.dir/moc_qgsmaprenderer.cxx.o] Error 1
make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
make: *** [all] Error 2
