AW: [Qgis-developer] legend problems
Tim Sutton lists at linfiniti.com
Thu Nov 4 06:57:46 EDT 2010
Hi
On Wed, 2010-11-03 at 19:05 +0100, Andreas Neumann wrote:
> I also had problems in the past - but I just compiled the current trunk
> and did not see any major problems (ubuntu 10.04, 64bit, qt4.6).
> Can you be more specific on what the problems are? Do you have the render
> cache active or not? The render cache caused a lot of problems in the
> past, so I generally disable it.
> I also think that those issue should be properly tested and resolved,
> before releasing QGIS 1.6.
Just to give my reassurance, we will hold the final release until
everybody is 100% happy with it. Ok well I'm exaggerating a little, but
we will try at least to not press the release button until I get a bunch
of +1's to an email stating I want to branch...
Regards
Tim
> Andreas
> On Wed, November 3, 2010 3:09 pm, Paolo Cavallini wrote:
> > Il 03/11/2010 14:39, Ziegler Stefan ha scritto:
> >> Hi
> >> yes, especially the latter one.
> > If so, I think this is a blocker for releasing 1.6.
> > Paolo Cavallini: http://www.faunalia.it/pc
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101104/1e87841e/attachment.bin
