[Qgis-developer] Re: New features in the field calculator
Jürgen E. Fischer jef at norbit.de
Mon Nov 8 14:30:28 EST 2010
Hi Borys,
On Mon, 08. Nov 2010 at 18:56:24 +0100, Borys Jurgiel wrote:
> Thanks for the great commit! I have one question: are comparision operators
> working already? You put them to the help, but I can't use them as I do in the
> Raster Calculator. You know, (A>2) * 3 + (A<=2) * 7
Hey, there are just four new functions.  The online help just lists what the
parser currently supports.  But the parser is used both for search strings and
in the field calculator - apparently the comparisons are only available in
search string.  Hence the "preliminary" - the documentation should probably
split in half one for the query builder and one for the field calculator.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
