[Qgis-developer] The case of ghost project!
Benoit de Cabissole benoit at exigesa.com
Thu Nov 11 02:58:13 EST 2010
 Hi Andreas,
Thanks for the reply. I will do it later...
Benoit
On 11/11/2010 08:53, Andreas Neumann wrote:
> Hi Benoit,
> Sounds like a bug - could you report?
> As a quick fix for yourself you can open the project file in a text editor
> and fix that file paths manually, until this problem is fixed.
> Andreas
> On Thu, November 11, 2010 7:20 am, Benoit de Cabissole wrote:
>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
>> <html>
>>   <head>
>>     <meta http-equiv="content-type" content="text/html;
>> charset=ISO-8859-1">
>>   </head>
>>   <body bgcolor="#ffffff" text="#000000">
>>     Hi all,<br>
>>     <br>
>>     A strange behaviour of QGIS R14517:<br>
>>     <br>
>>     I have a project in which two layers have been physically moved from
>>     the location pointed to in the project QGS file.<br>
>>     <br>
>>     After opening the QGS file, QGIS asks if I want to locate those
>>     files. I select Ok and navigate to the new location of those files
>>     to select them.<br>
>>     Then the QGIS interface is totally empty: empty legend and empty
>>     canvas, nothing at all... I went to project properties, selectable
>>     layers tab: all layers are listed there.<br>
>>     <br>
>>     Close QGIS and run it again on the same project, but I select Cancel
>>     when prompted to locate the missing layers. Result: exactly the
>>     same: nothing in the legend an nothing in the canvas.<br>
>>     <br>
>>     The canvas scale is correct and the coordinates in the status bar
>>     are also correct when the mouse moves over the canvas, but, again,
>>     absolutely nothing is displayed.<br>
>>     <br>
>>     I'm on Windows XP in OSGeo4W.<br>
>>     <br>
>>     Can you repeat this strange behaviour?<br>
>>     <br>
>>     BTW, is 1.5 standalone all is fine.<br>
>>     <br>
>>     Best regards,<br>
>>     Benoit<br>
>>     <br>
>>     <br>
>>     <br>
>>     <strong><font size="-1"><br>
>>         <br>
>>       </font></strong>
>>   </body>
>> </html>
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
