[Qgis-developer] Errors in OS X script
William Kyngesburye
woklist at kyngchaos.com
Mon Nov 15 11:07:39 EST 2010
... looks like the mapserver component was recently made optional, off by default. The error is harmless, but I'll fix it to check first.
If you want to test the mapserver, add to configuration:
-D WITH_MAPSERVER
On Nov 15, 2010, at 9:57 AM, John C. Tull wrote:
> Hi William,
> It appears that some script components in, at least, the MinSizeRel build are not working. They seem to be expecting a directory in the application bundle that is not present. The following is at the end of the 'make install' command:
> -- Updating QGIS library paths...
> install_name_tool: can't open file: /Applications/QGIS.app/Contents/MacOS/fcgi-bin/qgis_mapserv.fcgi (No such file or directory)
> My cmake command is this:
> cmake -D CMAKE_INSTALL_PREFIX=/Applications -D CMAKE_BUILD_TYPE=Release -D CMAKE_BUILD_TYPE=MinSizeRel -D WITH_INTERNAL_SPATIALITE=FALSE ..
> Cheers,
> John_______________________________________________
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
