[Qgis-developer]
	Re: Way forward: QGIS plugin repo, plugin Trac etc.
    Tim Sutton
    lists at linfiniti.com
    Wed Nov 17 04:32:33 EST 2010
On Mon, Nov 15, 2010 at 1:45 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi all
> There has been a lot of discussion about the way forward for plugins,
> the plugin repository, plugin source management and plugin issue
> tracking / bug reporting in the last few weeks. Sitting in the same
> room for the last few days, we have also been able to go into more
> detail about our requirements. We would like to summarise our
> requirements and plans and get things going. So here is the synopsis:
> 1) We will set up a django instance on the QGIS.org virtual machine
> (using a python vitual environment) for building the new QGIS Plugin
> Repository.
> 2) The code for the repository will be managed via GIT and is hosted
> on github. If you need write access, please provide me with your
> github user name. Details for the repo here:
> https://github.com/timlinux/qgis-django
So following Pirmin's advice I set up a communty repo on github rather
- I've deleted the original one.
https://github.com/qgis/qgis-django
If you need access to the new one - let us know and we can add you. My
apologies if you already wrote 10000 lines of code against the old
repo.
Regards
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
