[Qgis-developer] Plugin GdalTools - Build Virtual Raster (catalog) idea to develop
Giuseppe Sucameli sucameli at faunalia.it
Wed Nov 24 20:53:38 EST 2010
Germán,
2010/11/25 Germán Carrillo <carrillo.german at gmail.com>
> I mean, the Load Them All plugin receives a base directory and an extension
> (e.g. GML) to look for layers in the base directory and in its
> subdirectories. It also loads those layers to QGIS by managing the canvas
> setRenderFlag method to avoid an unnecessary waste of time in the process.
the BuildVRT tool add only one layer to canvas. I unable to find the waste
of time
in cases like this.
Instead managing the render flag would be pretty useful in batch tools (e.g.
Translate).
Thanks a lot, I'm going to improve each batch tool by properly
disabling/enabling the
render flag while it adds layers to canvas.
Cheers.
Regards,
> Germán
> 2010/11/24 Giuseppe Sucameli <sucameli at faunalia.it>
>> Hi Germán,
>> 2010/11/24 Germán Carrillo <carrillo.german at gmail.com>
>> I think you may reuse some code of the Load Them All Plugin [1] to
>>> accomplish this.
>> what did you mean writing "to accomplish this", to load the layers or
>> maybe to do a recursive scan?
>> Cheers.
>>> Regards,
>>> Germán
>>> [1]
>>> http://geotux.tuxfamily.org/index.php?option=com_myblog&task=view&id=264&Itemid=59&lang=en
>>>>  Hi Santiago,
>>>> On Wed, Nov 24, 2010 at 6:01 PM, Santiago Lastra <
>>>> santiago.lastra at gmail.com> wrote:
>>>>> Recently I've found this very interesting and useful tool, at least for
>>>>> me. I will propose two ways to improve the tool:
>>>>> - The tool right now offers the user the possibility to select as many
>>>>> files as he wants inside a directory. I propose to give also the possibility
>>>>> to define only a directory that contains raster files (of every kind), with
>>>>> a check box to give the oportunity to follow the subdirectories of the first
>>>>> one.
>>>> there's an opened ticket yet, see [1] ;)
>>>>  - I think it's better to explain my problem and I think you will
>>>>> understand the reason of my second proposal. I have directories with up to
>>>>> 2000 raster files or even more. If you try the tool as is and if you select
>>>>> "add to canvas", it takes several minutes to load and see the virtual raster
>>>>> catalog (VRT) into QGIS, but if I zoom in to the right scale QGIS move the
>>>>> images very quickly. What I suggest is to add in the dialog the possibility
>>>>> to define the "scale dependent visibility" when the VRT is added to the TOC
>>>>> of QGIS.
>>>> Why don't you stop the rendering? So you can set the "scale dependent
>>>> visibility"
>>>> range using the existent layer properties dialog.
>>>> Simply you can disable it either before you add the layer or while QGis
>>>> loads it.
>>>> Or maybe did I misunderstand?
>>>> Cheers.
>>>> [1] https://trac.osgeo.org/qgis/ticket/3095
>>>> Giuseppe Sucameli
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>   |\__
>>> (:>__)(
>>> Soluciones Geoinformáticas Libres
>> Giuseppe Sucameli
>   |\__
> (:>__)(
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101125/3550ac83/attachment.html
