[Qgis-developer] Re: compile from source qgis 1.6
sunil sunilrajkiran at gmail.com
Thu Nov 25 06:53:28 EST 2010
hi
  all above i have succesfully compiled qgis1.6.0 in xp using msys,mingw
compiler , the error which i said about the plugininstaller is successfully
solved by adding the files of python to qgis release packager folder while
creating setup.exe
and its is working fine when i installed in another xp machine
drawback of the created exe : 1) i didnt configure many drivers in gdal/ogr
library if you people suggest some ideas for that  will be helpful.
Regards
Sunil
View this message in context: http://osgeo-org.1803224.n2.nabble.com/compile-from-source-qgis-1-6-tp5769247p5773969.html
Sent from the qgis-developer mailing list archive at Nabble.com.
