AW: [Qgis-developer] Trace edit
Paolo Cavallini cavallini at faunalia.it
Sat Nov 27 03:59:24 EST 2010
Il 26/11/2010 13:05, Paolo Cavallini ha scritto:
> Il 26/11/2010 11:24, Möri Cedric ha scritto:
>> I will have a look on it at weekend. My first guess would be, that
>> this problem occurs, if you snap to feature that's not yet saved, ie.
>> freshly digitized. So saving the layer before using trace edit may
>> help. Can you confirm?
> I confirm that it happens with unsaved layers; I'll try with saved ones.
Now I keep on getting
The geometry of the feature you just added isn't valid. Do you want to use it anyway?
even if I digitize very simple (and valid) triangles. In fact, the cursor is always
green. Any explanation?
Thanks.
Paolo Cavallini: http://www.faunalia.it/pc
