[Qgis-developer] Proposed enhancement: WKT field in delimited
text plugin
Gary Sherman
gsherman at geoapt.com
Sun Nov 28 16:23:20 EST 2010
On Nov 28, 2010, at 11:59, Chris Crook <ccrook at linz.govt.nz> wrote:
> Hi
> I've submitted a proposed enhancement and patch to the delimited text plugin to provide support for WKT fields as a way of defining geometries, as an alternative to using X and Y fields to define points.
> I find this very useful for creating small data sets from scripts (eg perl/python), where I want to display line string or polygon geometries. Also it matches the data generated by copying features to the clipboard. So features can be copied into a text files and then displayed directly in QGIS. While this functionality is available via the OGR VRT virtual format, it is much easier to use directly from delimited text files.
> If this all looks Ok could this be installed into 1.7?
> Thanks
> Chris
I'm taking a look at it...
-Gary
GeoApt LLC
Chair, Quantum GIS PSC
> http://trac.osgeo.org/qgis/ticket/3259
> ______________________________________________________________________________________________________
> This message contains information, which is confidential and may be subject to legal privilege.
> If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
> If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
> LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
> Thank you.
> Qgis-developer mailing list
