[Qgis-developer] Re: [Qgis-user] qgis 1.6 crashes
Agustin Lobo
alobolistas at gmail.com
Mon Nov 29 12:08:23 EST 2010
Hi!
Not sure how to get the list of pluggins. What I do is sending you the
output sent to the console, I assume that the offending plugging must
be one those that appear as "loaded". Tell me if there is a better way.
It's certainly a problem with a plugging, as I've just found the same
problem on a third machine running qgis 1.6 (ubuntu 10.04),
I've also started to uninstall pluggings, no luck yet. Just know that
qgis --noplugins works fine:
alobo at HPepito:~$ qgis
Python support ENABLED :-)
Loaded : Geoprocessing (package: geoprocessing)
Loaded : Numerical Vertex Edit (package: numericalVertexEdit)
Loaded : Image Boundary (package: imgboundary)
Loaded : Table Manager (package: tablemanager)
Loaded : RasterCalc (package: rastercalc)
Loaded : GdalTools (package: GdalTools)
Loaded : Rectangles (package: rectangles)
Loaded : Quickly save default qml (package: quicksaveqml)
Loaded : Profile (package: profiletool)
Loaded : Raster File Info Plugin (package: rasterinfo)
/usr/lib/python2.6/dist-packages/osgeo/gdal.py:80: DeprecationWarning:
gdal.py was placed in a namespace, it is now available as osgeo.gdal
DeprecationWarning)
Loaded : DEM relief shader (package: shadedrelief)
Loaded : Mirror Map Plugin (package: mirrormap)
Loaded : Zip Layers (package: ziplayers)
Loaded : Zoom to Point - Modified-bb (package: zoom_to_point_BB)
Loaded : Raw raster file import (package: rawrasterfileimport)
Loaded : Closest Feature Finder (package: ClosestFeatureFinder)
Loaded : SelectPlus Menu (package: selectplus)
Loaded : 1-Band Raster Colour Table (package: bcccoltbl)
Loaded : CadTools (package: cadtools)
SUB marker line 1
Loaded : Symbology-NG (package: symbology_ng)
Loaded : Click-fu (package: clickfu)
Loaded : SRTM elevation importer for Qgis (package: qgissrtm)
Loaded : Reference Map Plugin (package: refmap)
Loaded : Rasterlang (package: rasterlang)
Loaded : PostGIS SQL Query Editor (package: postgisquery)
Loaded : Spectral Profile (package: spectral_profile)
NEW LOGGING | 29.11.2010 18:07:02 | SDA4PP, Version=0.195
CLASS NAME | FUNCTION NAME | VARIABLE NAME = VALUE
sda4pp | initGui | pyqt version= 4.6.2
LoadRlib | checkPartners | Checking rpy2.
rpy2 version= 2.0.8
LoadRlib | checkPartners | Checking R-cran.
LoadRlib | checkPartners | Plug-in will run, rpy2 and R are called.
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.7.3, released 2010/11/10
Path to GDAL shared files: /usr/share/gdal17
Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
Path to PROJ.4 shared files: (autodetected)
LoadRlib | loadRgdal | rgdal package loaded.
sda4pp | initGui | rgdal package is loaded.
Note: polygon geometry computations in maptools
depend on the package gpclib, which has a
restricted licence. It is disabled by default;
to enable gpclib, type gpclibPermit()
Checking rgeos availability as gpclib substitute:
FALSE
LoadRlib | loadMaptools | maptools package loaded.
sda4pp | initGui | maptools package is loaded.
This is mgcv 1.7-2. For overview type 'help("mgcv-package")'.
deldir 0.0-10
Please note: The process for determining duplicated points
has changed from that used in version 0.0-9.
spatstat 1.17-2 (Type ‘help(spatstat)’ for information)
LoadRlib | loadSpatstat | spatstat package loaded.
sda4pp | initGui | spatstat package is loaded.
wl | manageConfFile | mode = "writeInit"
wl | manageConfFile | index = ""
wl | manageConfFile | tool = ""
Loaded : Spatial Data Analysis for Point Pattern (package: SDA4PP)
Loaded : Google Layers (package: GoogleLayers)
Loaded : Plugin Installer (package: plugin_installer)
Loaded : Geocoding (package: GeoCoding)
Loaded : MultiQml (package: multiqml)
Loaded : RGB Composition Plugin (package: rgb)
Loaded : ShowHideImg (package: imgshowhide)
Loaded : 1-Band Raster Colour Table V1.x (package: bcccoltbl1)
Loaded : MapSheetAutoGeoRef (package: MapSheetAutoGeoRef)
Loaded : Image Clipper (package: image_clipper)
Loaded : manageR (package: manageR)
Loaded : Copypasta (package: copypasta)
Loaded : Scattergram (package: scattergram)
Loaded : TopoColour (package: topocolour)
Loaded : Point sampling tool (package: pointsamplingtool)
Loaded : OpenLayers Plugin (package: openlayers)
Loaded : Interactive Identify (package: infotool)
Loaded : Statist (package: statist)
Loaded : Colour Scale Bar (package: bccscbar)
Loaded : Value Tool (package: valuetool)
Loaded : DumpLoadField (package: dumpfield)
Loaded : fTools (package: fTools)
Loaded : MapServer Export (package: mapserver_export)
Error:
GDAL Error 4: `/media/FREECOM_HDD/VGT/SM/untitled folder/subs.bil'
does not exist in the file system,
and is not recognised as a supported dataset name.
Segmentation fault
2010/11/29 Giuseppe Sucameli <sucameli at faunalia.it>:
> Hi Agustin,
> On Mon, Nov 29, 2010 at 1:36 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
>> I think it is the gdal tools, as this is what I get on the console
>> after the crash:
>> Loaded : OpenStreetMap plugin (package: osm)
>> Error:
>> Error: use of NULL environment is defunct
>> During startup - There were 16 warnings (use warnings() to see them)
>> *** stack smashing detected ***: /usr/bin/qgis.bin terminated
>> Segmentation fault
> I'm pretty sure that the crash is not due to GdalTools.
> In fact GdalTools doesn't load anything since the user clicks on one of the
> tools in
> the Raster menu, instead seems that a plugin tries to load a .bil file from
> an invalid
> (maybe hard-coded) path...
> The "GDAL Error" message is printed by the libgdal, not the GdalTools plugin
> at all.
> BTW, can you send us a list containing the installed plugins?
> Cheers.
>> gdaltools are not there when I start with qgis --noplugins
>> but cannot uninstall it if I start normally, as it comes now bundled,
>> so I cannot fully test.
>> Agus
>> 2010/11/29 Agustin Lobo <alobolistas at gmail.com>:
>> > Has to be that, as the crash does not occur if I start qgis with
>> > qgis --noplugins
>> > I'll ty to identify the offending plugin, any ideas?
>> > Agus
>> > 2010/11/29 Jürgen E. <jef at norbit.de>:
>> >> Hi Agus,
>> >> On Mon, 29. Nov 2010 at 12:12:50 +0100, Agustin Lobo wrote:
>> >>> No crash for vector layers, crash for raster layers.
>> >>> The test consists of:
>> >>> 1. Open qgis and load a raster layer
>> >>> 2. Save the project and close qgis
>> >>> 3. move or rename the raster layer
>> >>> 4. Open qgis and open the saved project
>> >>> 5. Crash
>> >> Do have anything "unusual" installed? Like custom build GDAL and/or
>> >> plugins
>> >> other might not have?
>> >> Jürgen
>> >> Jürgen E. Fischer norBIT GmbH Tel.
>> >> +49-4931-918175-20
>> >> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>> >> +49-4931-918175-50
>> >> Software Engineer D-26506 Norden
>> >> http://www.norbit.de
>> >> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme
>> >> mbH
>> >> Rheinstrasse 13, 26506 Norden
>> >> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giuseppe Sucameli
