[Qgis-developer] Re: sample dataset including plug-ins (=> was: Re:
[Qgis-user] Announcing "Time Manager" Plugin v 0.1)
Noli Sicad
nsicad at gmail.com
Mon Oct 4 22:34:43 EDT 2010
Hi Pierre,
This is very good idea.
I myself don't deal with raster data at this moment, hence, all those
plugins dealing with raster is no use to me at this moment.
(Cross posted to Qgis developer)
Let see the developers feedbacks on your suggestions.
Noli
On 10/5/10, Pierre Chevalier Géologue <pierrechevaliergeol at free.fr> wrote:
> Hello,
> I start another thread, based on the discussion about time manager dataset.
> Noli Sicad claviota:
>> Very good point. Probably you can have 2 versions with data and
>> without data. I suggest that probably you can put a link, a button to
>> get the sample data in one of the plugin widgets. These are all
>> suggestions to improve usabilities of the qgis plugins in general.
> Yes, I plussoie beaucoup. I agree, in a more proper language.
>> Some of QGIS plugins are hard to figure out if you don't have a properly
>> data to work on. And most of the users, have no real use of the plugin at
>> the time the plugin is announced and just like to see how it works.
> Yes. And this is particularly true in GIS software.
> If you look at R, for instance, they provide datasets that can be
> accessed so simply. It is excellent, because you are able to *really*
> play with data in a matter of seconds, literally.
> For instance, in R, all you have to do is:
> contour(10 * (1:nrow(2 * volcano)), 10 * (1:ncol(2 * volcano)), 1.5
> * volcano, pretty(range(volcano)))
> To get, in ONE line, a contour map from a volcano in New Zealand.
> Similarly, to get a perspective view of the same data:
> persp(10 * (1:nrow(2 * volcano)), 10 * (1:ncol(2 * volcano)), 1.5 *
> volcano, theta = 140, phi = 30, scale = FALSE, axes = FALSE, shade =
> 0.5, border = NA)
> In fact, the variable 'volcano' seems to directly contain a whole
> dataset. No need to do any file/open or anything.
> Another example with another dataset provided with R, 'iris':
> pairs(iris[1:4], main="Edgar Anderson's Iris Data", pch=21,bg =
> c("red", "green3", "blue")[unclass(iris$Species)])
> In my humble opinion, this solution is extremely effective, from the
> end-user-beginner point of view.
> Now, back to qgis: there is already the Alaska dataset, also the grass
> spearfish dataset.
> I would be in favour of compiling a "state-of-the-art" complete dataset,
> so that users can play immediately with it, and get a good feeling about
> softwares. Not only plug-ins, but the whole thing. This could be a sort
> of standard, a base on which any GIS newbie could rely on to make his
> own dataset: just erase all example data, and fill with your own, and
> you're up and running.
> Such a dataset has, of course, to be free (freedom), it may have data
> such as:
> - an srtm dem,
> - a topo map,
> - gpx data,
> - satellite imagery
> - a scanned geological map (sorry, "je prêche pour ma paroisse"
> => if someone
> knows the English
> translation, go on and translate ;)
> - a scanned pedological map,
> - a set of pictures taken from the ground, geotagged,
> - buildings as vectors,
> - roads as vectors,
> - "field occupation" (occupation du sol, in French: not sure about
> translation) as vectors,
> - a postgis database,
> - an sqlite database,
> - a mysql (forgot about postgis equivalent, sorry) database,
> - a whole grass dataset,
> - etc, etc. (unlimited)
> Then, any plug-in developer should add to this dataset some sample data.
> I think such a sample dataset should be:
> - well-structured (state of the art => so that the GIS newbies can
> inherit from the experience/errors from senior users),
> - small, in terms of size: this way, when a user tries some features,
> it doesn't run for hours or colonize the whole user's RAM,
> - available separately from the software itself (regarding issues
> mentioned during the initial discussion); if it was for instance a linux
> package, it could be something like qgis-sample-data.
> The "spearfish" dataset could well be a base for such an exercise. Or
> Alaska.
> Or anything else. There was a "Doncaster" totally fake dataset, provided
> with GDM (geological package): it was invented, by mixing different data
> from various places, mangling data.
>> I hope if it will be in python plugin repository soon. I just like to try
>> it.
> If such a solution was adopted, then every plugin developer should add
> relevant data in the sample data set. Or, maybe, publish on the
> repository a small dataset, which would make the complement of the
> existing whole dataset?
> Your opinions? Silly ideas? Utopia?...
> A+
> Pierre
> ____________________________________________________________________________
> Pierre Chevalier Géologue EI
> Mesté Duran
> 32100 Condom
> Tél+fax : 09 75 27 45 62
> 05 62 28 06 83
> 06 37 80 33 64
> Émail : pierrechevaliergeolCHEZfree.fr
> icq# : 10432285
> skype : pierre.chevalier1967
> http://pierremariechevalier.free.fr/pierre_chevalier_geologue
