[Qgis-developer] Raster algebra C++
Paolo Cavallini cavallini at faunalia.it
Thu Oct 14 13:40:59 EDT 2010
Il 14/10/2010 17:40, Marco Hugentobler ha scritto:
> So here is my initial patch that implements a calculator tool as part of the
> analysis library by extending the search string mechanism.
Great, thanks Marco and Tim! This was much needed.
> - Possibility to insert output extent and resolution and do calculations with
> layers that have different resolutions / extent.
That is a big win: without this, the current plugin is of limited use. Without the
limitation, this can replace GRASS r.mapcalc, at least for simple tasks (i.e. no
neighbours analyses).
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
