[Qgis-developer] porjectRead() and newProject() signals
Alexander Bruy
alexander.bruy at gmail.com
Mon Oct 18 03:55:09 EDT 2010
Hi
Some plugins stores their settings in QGIS project. And when user open
previously saved project read setting from it, when created new project -
default settings used and plugin GUI is resetted. For example in Copyright
label plugin
void QgsCopyrightLabelPlugin::initGui()
//this resets this plugin up if a project is loaded
connect( qGisInterface->mainWindow(), SIGNAL( projectRead() ), this,
SLOT( projectRead() ) );
//initialise default values in the gui
projectRead();
But projectRead() and newProject() are not documented, some info available
only in qgisapp.h. Is it possible to add this signals to the QGisInterface
and add some documentaion?
Alexander Bruy
