[Qgis-developer] wfs-t and tinyows
Vincent Picavet
vincent.ml at oslandia.com
Tue Oct 26 08:28:54 EDT 2010
> Just testing qgis with TinyOWS: quite a nice combination.
> The only problem I found: I can add geometries, but not edit exixting ones:
> Impossibile applicare le modifiche al layer tows:wfs_t
> Errori: SUCCESSO: 1 geometrie aggiunte.
> ERRORE: 1 geometrie non cambiate.
It may be TinyOWS's fault.
Did you try with latest TinyOWS trunk ? A lot of bugs have been fixed since 0.9
release.
You should also look at TinyOWS logs so that you can figure out if it's a
problem with TinyOWS or with QGIS WFST support.
Vincent
Vincent Picavet - vincent.picavet at oslandia.com
www.oslandia.com - Engineering your GIS
