[Qgis-developer] wfs-t and tinyows
Vincent Picavet vincent.ml at oslandia.com
Tue Oct 26 12:21:51 EDT 2010
> > It may be TinyOWS's fault.
> > Did you try with latest TinyOWS trunk ? A lot of bugs have been fixed
> since 0.9 release.
> We are using 0.9.0-3 (thanks Pirmin).
Ok, then maybe giving current svn trunk a chance would solve your problem.
> > You should also look at TinyOWS logs so that you can figure out if it's a
> > problem with TinyOWS or with QGIS WFST support.
> Where do I find it?
You have to set the location in TinyOWS config file : «log» attribute of TinyOWS
element :
http://www.tinyows.org/trac/wiki/ConfigFile
Vincent
Vincent Picavet - vincent.picavet at oslandia.com
www.oslandia.com - Engineering your GIS
