[Qgis-developer] ED50 datum
Paolo Cavallini cavallini at faunalia.it
Tue Sep 7 06:09:02 EDT 2010
Il 07/09/2010 11:57, Frank Warmerdam ha scritto:
> For some reason, this EPSG derived towgs84 value is slightly
> different than the one you propose.  I would like to encourage
> the QGIS team to work with me to ensure that such adjustments
> are not done differently in QGIS than in the upstream database.
Thanks a lot Frank.
It is certainly better to use the new EPSG than patching it (improperly, as you show)
downstream.
Any idea on when this new EPSG will be release? Or perhaps we can incorporate the one
from trunk into qgis?
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
