[Qgis-developer] plugin_builder.py Makefile not working
Tim Keitt
tkeitt at gmail.com
Thu Sep 9 18:20:53 EDT 2010
I generated a QGIS plugin skeleton using plugin_builder.py. After
modifying the ui using Qt Designer, I figured I should be able to type
'make' and reload the plugin. The generated Makefile however does not
seem to work. Any hints?
THK
tkeitt at ubuntu-vbox:~/.qgis/python/plugins/meshpoly$ make
make: *** No rule to make target `compile', needed by `default'. Stop.
# Makefile for a PyQGIS plugin
UI_FILES = Ui_MeshPoly.py
RESOURCE_FILES = resources.py
default: compile
compile: $(UI_FILES) $(RESOURCE_FILES)
%.py : %.qrc
pyrcc4 -o $@ $<
%.py : %.ui
pyuic4 -o $@ $<
Timothy H. Keitt
http://www.keittlab.org/
