[Qgis-developer] Feature Form
Bernhard Ströbl
Bernhard.Stroebl at jena.de
Tue Sep 14 04:45:07 EDT 2010
Hi Richard,
thank you for your answer. What you describe is exactly what I am aiming
at: I have a custom form (ui) which should pop up when the user clicks
on a menu-action. There is some Python work on selected geometries prior
to the form showing. I could of course translate the form into Python
but then I would have to programmatically enter all form values in their
respective fields. Generally speaking I like to use as much
out-of-the-box functionality, so for users the plugin behaves as they
would expect from their prior experience using QGIS.
all the best
Bernhard
Richard Duivenvoorde schrieb:
> Hi Bernard,
> I don't know, but looking at the dev's:
> I think it would be really usefull (with the right pointers I vollunteer
> to make an example in the wiki) because in that way it would be very
> easy to make a 'custom input plugin', in which a combination of a custom
> form and some pre-show and post-show python magic can make a great input
> application (I'm thinking about some field application in which some
> inputs are generated based on earlier inputs, or gps location etc etc).
> Hope you get some input.
> Regards,
> Richard
> Bernhard Ströbl wrote:
>> Hi all,
>> I have asked this last week already but got no response. Is it possible
>> to open the feature form from a python script?
>> Maybe the answer is so obvious that nobody felt responsible to give it.
>> I read the api-doc back and forth and did not find any clue. So if I was
>> asked I would answer no, this is not possible. Can anybody confirm (or
>> better disprove :) this?
>> regards
>> Benno
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
Dipl.-Geogr. Bernhard Ströbl
Anwendungsbetreuer GIS
Kommunale Immobilien Jena
- Datenverarbeitung -
mailto:Bernhard.Stroebl at jena.de
http://kij.jena.de/
