Fwd: Re: [Qgis-developer] FreeEditing plugin
Paolo Cavallini
cavallini at faunalia.it
Tue Sep 14 08:04:53 EDT 2010
On Tue, 14 Sep 2010 12:56:58 +0200, Ivan Mincik <ivan.mincik at gista.sk>
wrote:
> Yes, this will happen because it will try to create polygon feature from
> one point geometry. We should catch such features and do nothing on them.
OK.
> There is a problem with QGIS simplify function, which is creating empty
> features in case when you draw feature vertexes very near to each other.
> Maybe there is some problem with decimal numbers.
> Try to zoom out and You can use simplify > 1.0.
I see. So why not setting an optimal (?) parameter and letting user just
tune it (say, +-50% respect to the optimal value)? Currently it is rather
difficult to use.
Thanks a lot.
http://faunalia.it/pc
