[Qgis-developer] Qgis standalone apps
Massimo Di Stefano massimodisasha at yahoo.it
Wed Sep 15 08:58:04 EDT 2010
Hi Giuseppe,
i tried with the "args" variable,
i have :
MacBook-Pro-15-di-sasha:~ sasha$ python /qgistry.py
  File "/qgistry.py", line 66, in <module>
    app = MainApp(sys.args)
AttributeError: 'module' object has no attribute 'args'
so i tried also without the "args" value,
what i'm missing ?
thanks to help me,
Massimo.
Il giorno 15/set/2010, alle ore 14.16, Giuseppe Sucameli ha scritto:
> Hi Massimo,
> as I wrote to you:
> class MainApp(QApplication):
>     def __init__(self, args):
>         QApplication.__init__(self, args)
>         wdg = MyWdg()
>         wdg.show()
>         self.exec_()
> if __name__ == "__main__":
>         import sys
> That is, you missed the "args" variable ;)
> Cheers.
> On Wed, Sep 15, 2010 at 1:52 PM, Massimo Di Stefano <massimodisasha at yahoo.it> wrote:
> sorry, i correct the link to the code i'm tring.
> my apologize :-/
> this one should work :
>> http://www.geofemengineering.it/data/qgistry.py
> Il giorno 15/set/2010, alle ore 12.21, Massimo Di Stefano ha scritto:
>> Hello All,
>> i'm tring to apply the changes you suggest me .. but with no good results
>> (again my fault)
>> i tried to change the code to :
>> http://www.geogemengineering.it/data/qgistry.py
>> but i got :
>> python /qgistry.py
>>   File "/qgistry.py", line 68, in <module>
>>     app = MainApp()
>>   File "/qgistry.py", line 61, in __init__
>>     QApplication.__init__(self)
>> TypeError: arguments did not match any overloaded call:
>>   QApplication(list-of-str): not enough arguments
>>   QApplication(list-of-str, bool): not enough arguments
>>   QApplication(list-of-str, QApplication.Type): not enough arguments
>> can you help me to have it running ?
>> thanks a lot !!!
>> Massimo.
>> Il giorno 10/set/2010, alle ore 02.07, qgis-developer-request at lists.osgeo.org ha scritto:
>>> Hi Massimo,
>>> On Fri, Sep 10, 2010 at 12:10 AM, Massimo Di Stefano <
>>>> Hi All,
>>>> i'm tring to start some coding on the qgis api
>>>> i'm on osx 10.6.4 running qgis 1.6
>>>> following the example from :
>>>> http://mapserver.sk/~wonder/qgis/html/canvas.html#using-map-tools-with-canvas<http://mapserver.sk/%7Ewonder/qgis/html/canvas.html#using-map-tools-with-canvas>
>>>> it works fine if i call it from a qgis-python shell
>>>> but i tried to make small changes to have it running as a standalone
>>>> application,
>>>> i eliminated the "layer" from the init line :
>>>> QMainWindow.__init__(self)
>>>> used a custom extent :
>>>> self.canvas.setExtent('15.1845401903089403,40.6214856769878665 :
>>>> 15.2339879807105998,40.6477493100907381')
>>>> and commented out the line :
>>>> #self.canvas.setLayerSet( [ QgsMapCanvasLayer(layer) ] )
>>>> then from a standard python shell, i tried :
>>>>>>> import mywnd
>>>>>>> dir(mywnd)
>>>> ['MyWnd', 'QAction', 'QMainWindow', 'QString', 'QgisInterface',
>>>> 'QgsAnnotationItem', 'QgsColorButton', 'QgsColorButtonV2',
>>>> 'QgsComposerView', 'QgsEncodingFileDialog', 'QgsFormAnnotationItem',
>>>> 'QgsGenericProjectionSelector', 'QgsLegendInterface', 'QgsMapCanvas',
>>>> 'QgsMapCanvasItem', 'QgsMapCanvasLayer', 'QgsMapCanvasMap',
>>>> 'QgsMapCanvasSnapper', 'QgsMapOverviewCanvas', 'QgsMapTip', 'QgsMapTool',
>>>> 'QgsMapToolEmitPoint', 'QgsMapToolPan', 'QgsMapToolZoom',
>>>> 'QgsMessageViewer', 'QgsProjectBadLayerGuiHandler', 'QgsProjectionSelector',
>>>> 'QgsQuickPrint', 'QgsRendererV2PropertiesDialog', 'QgsRendererV2Widget',
>>>> 'QgsRubberBand', 'QgsStyleV2ManagerDialog', 'QgsSymbolLayerV2Widget',
>>>> 'QgsSymbolV2PropertiesDialog', 'QgsSymbolV2SelectorDialog',
>>>> 'QgsTextAnnotationItem', 'QgsVertexMarker', 'Qt', 'SIGNAL', '__builtins__',
>>>> '__doc__', '__file__', '__name__', '__package__']
>>>>>>> w = mywnd.MyWnd()
>>>> QWidget: Must construct a QApplication before a QPaintDevice
>>>> Abort trap
>>> the MyWnd is a QWidget.
>>> You must create a QApplication instance and only after this you can
>>> show widgets within it.
>>> Here an example (main.py):
>>> from PyQt4.QtGui import QApplication
>>> from mywdg import MyWdg
>>>        wdg = MyWdg()
>>>        wdg.show()
>>>        self.exec_()
>>>        import sys
>>> Then open a terminal and run: python main.py
>>> and if all went fine you can see your widget.
>>> Cheers.
>>>> it give me a python crash ... obviously i'm missing something basilar,
>>>> have you any clue on what i need to change to have the example working
>>>> outside qgis ?
>>>> thanks a lot !!!
>>>> regards,
>>>> Massimo
> Qgis-developer mailing list
> Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100915/b4b9c952/attachment-0001.html
