[Qgis-developer] Qgis standalone apps
Giuseppe Sucameli
brush.tyler at gmail.com
Wed Sep 15 09:33:00 EDT 2010
oops... sys.argv :)
On Wed, Sep 15, 2010 at 2:58 PM, Massimo Di Stefano <massimodisasha at yahoo.it
> wrote:
> Hi Giuseppe,
> i tried with the "args" variable,
> i have :
> MacBook-Pro-15-di-sasha:~ sasha$ python /qgistry.py
> Traceback (most recent call last):
> File "/qgistry.py", line 66, in <module>
> app = MainApp(sys.args)
> AttributeError: 'module' object has no attribute 'args'
> so i tried also without the "args" value,
> what i'm missing ?
> thanks to help me,
> Massimo.
> Il giorno 15/set/2010, alle ore 14.16, Giuseppe Sucameli ha scritto:
> Hi Massimo,
> as I wrote to you:
> class MainApp(QApplication):
> def __init__(self, args):
> QApplication.__init__(self, args)
> wdg = MyWdg()
> wdg.show()
> self.exec_()
> if __name__ == "__main__":
> import sys
> That is, you missed the "args" variable ;)
> Cheers.
> On Wed, Sep 15, 2010 at 1:52 PM, Massimo Di Stefano <
> massimodisasha at yahoo.it> wrote:
>> sorry, i correct the link to the code i'm tring.
>> my apologize :-/
>> this one should work :
>> http://www.geofemengineering.it/data/qgistry.py
>> Il giorno 15/set/2010, alle ore 12.21, Massimo Di Stefano ha scritto:
>> Hello All,
>> i'm tring to apply the changes you suggest me .. but with no good results
>> (again my fault)
>> i tried to change the code to :
>> http://www.geogemengineering.it/data/qgistry.py
>> but i got :
>> python /qgistry.py
>> File "/qgistry.py", line 68, in <module>
>> app = MainApp()
>> File "/qgistry.py", line 61, in __init__
>> QApplication.__init__(self)
>> TypeError: arguments did not match any overloaded call:
>> QApplication(list-of-str): not enough arguments
>> QApplication(list-of-str, bool): not enough arguments
>> QApplication(list-of-str, QApplication.Type): not enough arguments
>> can you help me to have it running ?
>> thanks a lot !!!
>> Massimo.
>> Il giorno 10/set/2010, alle ore 02.07,
>> qgis-developer-request at lists.osgeo.org ha scritto:
>> Hi Massimo,
>> On Fri, Sep 10, 2010 at 12:10 AM, Massimo Di Stefano <
>> Hi All,
>> i'm tring to start some coding on the qgis api
>> i'm on osx 10.6.4 running qgis 1.6
>> following the example from :
>> http://mapserver.sk/~wonder/qgis/html<http://mapserver.sk/%7Ewonder/qgis/html>
>> /canvas.html#using-map-tools-with-canvas<
>> http://mapserver.sk/%7Ewonder/qgis/html/canvas.html#using-map-tools-with-canvas
>> it works fine if i call it from a qgis-python shell
>> but i tried to make small changes to have it running as a standalone
>> application,
>> i eliminated the "layer" from the init line :
>> QMainWindow.__init__(self)
>> used a custom extent :
>> self.canvas.setExtent('15.1845401903089403,40.6214856769878665 :
>> 15.2339879807105998,40.6477493100907381')
>> and commented out the line :
>> #self.canvas.setLayerSet( [ QgsMapCanvasLayer(layer) ] )
>> then from a standard python shell, i tried :
>> import mywnd
>> dir(mywnd)
>> ['MyWnd', 'QAction', 'QMainWindow', 'QString', 'QgisInterface',
>> 'QgsAnnotationItem', 'QgsColorButton', 'QgsColorButtonV2',
>> 'QgsComposerView', 'QgsEncodingFileDialog', 'QgsFormAnnotationItem',
>> 'QgsGenericProjectionSelector', 'QgsLegendInterface', 'QgsMapCanvas',
>> 'QgsMapCanvasItem', 'QgsMapCanvasLayer', 'QgsMapCanvasMap',
>> 'QgsMapCanvasSnapper', 'QgsMapOverviewCanvas', 'QgsMapTip', 'QgsMapTool',
>> 'QgsMapToolEmitPoint', 'QgsMapToolPan', 'QgsMapToolZoom',
>> 'QgsMessageViewer', 'QgsProjectBadLayerGuiHandler',
>> 'QgsProjectionSelector',
>> 'QgsQuickPrint', 'QgsRendererV2PropertiesDialog', 'QgsRendererV2Widget',
>> 'QgsRubberBand', 'QgsStyleV2ManagerDialog', 'QgsSymbolLayerV2Widget',
>> 'QgsSymbolV2PropertiesDialog', 'QgsSymbolV2SelectorDialog',
>> 'QgsTextAnnotationItem', 'QgsVertexMarker', 'Qt', 'SIGNAL',
>> '__builtins__',
>> '__doc__', '__file__', '__name__', '__package__']
>> w = mywnd.MyWnd()
>> QWidget: Must construct a QApplication before a QPaintDevice
>> Abort trap
>> the MyWnd is a QWidget.
>> You must create a QApplication instance and only after this you can
>> show widgets within it.
>> Here an example (main.py):
>> from PyQt4.QtGui import QApplication
>> from mywdg import MyWdg
>> wdg = MyWdg()
>> wdg.show()
>> self.exec_()
>> import sys
>> Then open a terminal and run: python main.py
>> and if all went fine you can see your widget.
>> Cheers.
>> it give me a python crash ... obviously i'm missing something basilar,
>> have you any clue on what i need to change to have the example working
>> outside qgis ?
>> thanks a lot !!!
>> regards,
>> Massimo
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Giuseppe Sucameli
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100915/944eb3c3/attachment.html
