[Qgis-developer] Re: cmake error on OS X 10.6
John C. Tull
john.tull at wildnevada.org
Fri Sep 17 18:25:07 EDT 2010
William knows much more about all of this than I do. With that said, I am a significant portion of the testing on OS X, and I have never used python.org. I would say dump it if you don't explicitly need it. Also, work out getting a build system for qgis that works, then start to tinker if you have to do so.
Cheers,
John
On Sep 17, 2010, at 4:16 PM, William Kyngesburye wrote:
> There are 2 camps on this: system and python.org, though I don't want to start a debate about that here ;) Both are valid, though I prefer the system version, and it's also the one most tested with Qgis as far as I know.
> If you want to uninstall python.org, deleting /Library/Frameworks/Python.framework is a start. It probably also has added something to your PATH in your ~/.bash_profile. And there also may be symlinks and scripts in /usr/local/bin, and maybe some headers or symlinks in /usr/local/include.
> On Sep 17, 2010, at 4:49 PM, Matthew Denno wrote:
>> John, I guess the only reason was that I wanted to use Idle at one time. I don't care anymore though. In your opinion would it be better uninstall the python.org version? Will that remove \Library\Frameworks\Python.frameworks...?
>> I am just trying to figure out how to proceed to get this cleaned up and working.
>>> On Sep 17, 2010 5:41 PM, "John C. Tull" <john.tull at wildnevada.org> wrote:
>>> Matthew,
>>> Is there a specific reason to use python.org? Generally speaking, it seems to prove best on OS X to avoid overriding system provided bins and libs when possible.
>>> Cheers,
>>> John
>>> On Sep 17, 2010, at 1:39 PM, William Kyngesburye wrote:
>>>> I think it will default to 32bit.
>>>> O...
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
